looking for an easy way to adjust springer front end on softail
Bought an 06 springer frontend for my Nightrain, looking for an easy way to set the bearings , fall away. Help...
RE: looking for an easy way to adjust springer front end on softail
You got a Svc Manual????
That is by far the EASIEST and most accurate description.... Make sure that your plumb bob is of the plastic coated type, so if it does bump into the bike (Shouldn't if done properly), it won't mar the finish... You will need a few oversized tools to do JUST the Rocker Bearing pre-load... What a joy that is.... 1 1/2" crowsfoot wrench, 1/2" Hex bit, 1/4 Dial type Torque Wrench (0-50 in/Lbs), 1/2" Torque wrench (0-100 Ft/Lbs)... |
© 2024 MH Sub I, LLC dba Internet Brands
