1996 Fatboy Fluid Change
I changed all the fluids in my Fatboy last night for the first time. Had no issues except for one. The transmission drain plug (torx) sits right above a wiring harness and is on the side of the transmission case. Is there some sort of device that would work well in the future for draining the trans oil away from the frame of the bike. As it drained it ran right over the frame and wiring harness. I wiped it down very well, but would like to avoid in the future. I can probably come up with some tubing of sorts, but didn't know if Harley made a tool for this. Wish the drain plug was under the trans like some other models.
Secondly, I see that Harley makes a "Oil Catcher Drain Oil Funnel" for when removing the oil filter for later models. Do they have an equivalent for the EVO models? I was thinking of just cutting up a plastic gutter extender for future use, but if they make a tool that would probably be better.
Thanks all for your help.
I changed all the fluids in my Fatboy last night for the first time. Had no issues except for one. The transmission drain plug (torx) sits right above a wiring harness and is on the side case of the transmission case. Is there some sort of device that would work well in the future for draining the trans oil away from the frame of the bike. As it drained it ran right over the frame and wiring harness. I wiped it down very well, but would like to avoid in the future. I can probably come up with some tubing of sorts, but didn't know if Harley made a tool for this. Wish the drain plug was under the trans like some other models.
