Turn Signal Module bad?
i got a new module $120 bucks the one in between the tanks. and still have the same problem!!!!!!!! f*&^% been at this for a few days now. i traced all the wires and not a dang thing. Right side works good. no broken wires i even swapped the leads just to make shure the left side work and it did just not getting the not getting signal back out of that box to the lights WTF!!!!!!!!!!! HELP!
Y'all doing all this work....
Take it out of the loop... Then you will know...
I'm talking about the run/stop/turn module
That's added in to make the rear signals come on for other than just left or right turning.
Those things cost. 49.99 or so...,
Put it on yourself! Tajes 3 1/2 seconds, no tools...
Well maybe a quarter to undo your seat bolt...
How do you know it's not bulbs or connections....? The OP thought all his connections were good, too. It's always best to do a systematic check of the system, with a voltmeter, before throwing parts at it. As you have found out, throwing parts at a problem can get expensive.
If you don't want to go to a dealer or independent, this might be a good time to get the electronic diagnostic manual for your bike model/year... Whenever I get a bike, I always buy the HD Service Manual, Parts Manual (the exploded diagrams help me a lot), and the Electronic Diagnostic Manual for that bike. Admittedly, I use the electronic diagnostic manual the least, but it's worth it's weight in gold when I need it! If you have, or you can check online, the Owner's Manual for your bike, almost all the way to the back, it will list the part numbers for the manuals that correspond to your bike. You can usually find then new/used on eBay, but I've had good luck with even some of the older manuals, buying them from the online HD parts sellers.... a few times I've gotten older, new manuals cheaper from online HD parts vendors, than the used ones listed on eBay.
Good luck with your trouble shooting/ repair....
