engine temp sensor
Old Oct 30, 2017 | 06:54 PM
Pitbull_Dallas's Avatar
Pitbull_Dallas
There's nothing on the rear cylinder that I'm aware of..
Old Oct 30, 2017 | 07:14 PM
Bone Doc's Avatar
Bone Doc
Originally Posted by LostTiny
I thought it was on the rear cylinder, or does temp sensor different from the ETIMS sensor ?
The Engine Idle Temperature Management System (EITMS) is a system, or a set of conditions, not a sensor. The EITMS is activated or deactivated based upon certain conditions (engine temperature, vehicle speed, engine rpms and throttle position). The individual conditions are determined by sensors.
The Engine Temperature Sensor provides one piece of information for the Engine Idle Temperature Management System. When all conditions of the EITMS are met, the ECM will activate the EITMS to cut fuel to the rear cylinder fuel injector. When conditions are not met (any one of them), the ECM will deactivate the EITMS and resume fuel to the rear injector.
Old Oct 30, 2017 | 10:25 PM
S.D.M.F's Avatar
S.D.M.F
Front cylinder, behind the horn.
Installing new ET sensor
- Hand start sensor 2 - 3 turns by hand
- Tighten to 10 - 15 ft-lbs
- Connect sensor connector
- Pull boot over connector.
Done.
Old Oct 27, 2023 | 07:53 AM
JMetalhead's Avatar
JMetalhead
Stage IV
Originally Posted by mke125125
anybody know what this is or does? my 04 heritage is showing a code and the dealer said its the temp sensor. he also said 3 to 4 hundred bucks to fix
I have a 03 Heritage and it wasn’t throwing any codes but all the info I’m reading takes me to the temp sensor,I paid 15.00 for it on Amazon and it’s located behind the horn,mines being delivered today and I can’t wait to install it to see if this is gonna solve my problem
Kansan
14
Apr 1, 2023 02:22 PM
WoodButcher66
2014-2024 Touring Models
May 31, 2021 06:08 PM
texas ultra
Jul 12, 2016 01:35 AM
armydoc78
Oct 18, 2014 11:07 AM
alazlo
Jun 11, 2007 01:49 PM
