Samson True Duals s2-439 on 09 Deluxe Install Help
Hey folks,
I just got my samson true duals in yesterday, got through everything pretty well in the instructions until it came to the "mount the muffler mounts in the stock positions". Now while I understand the right side, though it looks like those two bolts will have to be replaced with longer ones, I'm a little sketchy as to the following:
1) left side, where is this "stock location" exactly? I can find two little plastic filler plugs on this side that correspond to the right side where there were two bolts but the holes these plugs are in don't look like they big enough for the bolts that came with the system. Is this the right place? Does anyone have any good pictures of these brackets mounted?
2) Right side, where there are already bolts. Do I replace these bolts with the ones in the kit? if I remove that plate that sandwhiches the head of these bolts, I'm not going to release something that will cause the rear end to need to be "readjusted" or anything like that am I?
Thanks in advance,for any help you can provide.
Thanks! That gives me some hope at least. From what I could tell on the right side, when I removed the two nuts off the two existing bolts there the rest of that "panel", for a lack of a better description, there was only one more allen head bolt holding the panel on. Do I just remove that and swap the bolts out?
At the very lower rear of the frame on both sides you should have holes with black plastic plugs in them.Remove the plugs from both sides and those are the only holes you will be using to install the tailpipes.You do not use any factory hardware you removed.You only need the nuts,bolts,and washers supplied in the kit.I had to install the brackets on the tailpipes first to make the installation much easier.Dont forget to use a little high temp sealer where there the pipes connect together and keep everything loose until every part has been installed.
Thanks for all the replies so far folks. It's more appreciated than you could know. 11:30 last night I finally gave up for the night. Samson's documentation leaves a little be desired in the examples and details area. If anyone has any more suggestions and/or pictures that would be awesome.
I believe you must remove the stock muffler mount from the right side and use the new muffler mount that came with the new system with two 3/8th bolts. You just pull the plastic plugs on the left side and attach the muffler mount there with the two other 3/8th bolts. That's how it worked on mine.
