Harley Davidson Forums
Harley Davidson Forums (https://www.hdforums.com/forum/)
-   Softail Models (https://www.hdforums.com/forum/softail-models-7/)
-   -   Console nut - won't loosen, won't tighten (https://www.hdforums.com/forum/softail-models/638153-console-nut-wont-loosen-wont-tighten.html)
Keithhu May 1, 2011 05:55 AM
I've had the console off several times without issue - I did the speedo swap and a garage door mod.
Now I need to tweak the garage door opener (short range, probably needs a new battery), but the dang nut just turns without any additional loosening. The console seems secure on the bike, but it will also turn the other way without getting any tighter.
Any advice appreciated....
IronAss May 1, 2011 06:35 AM
I seem to remember the bolt the nut attaches to being like a carriage type bolt and sitting in a recess. It might have slipped out and is just turning with the nut.
You might try taking a small flat screwdriver of whatever will fit and slipping it between the dash and the nut and applying upward pressure while turning the nut. This might pull the head of the bolt up against the plate enough to cause it to stop turning.
Of course I could be wrong. I guess I could go out and take mine apart to see exactly whats in there that could be causing you a problem and maybe I will if that doesn't do it for ya.
challutz May 1, 2011 06:36 AM
Sounds like the other end of the bolt which is carriage type slipped out of the slot. Try pulling upward while turning to get it to engage back into the slot. If that doesnt work it may have to be cut off. I would use a dremel and protect evrything around it.
Keithhu May 17, 2011 07:42 PM
Update on this for anyone who cares. Apparently the bolt is square at the base, and it goes into a square slot in a plate that sits on the tank.
Spoke with a tech at the dealer today, he says the bolt is probably rounded off at this point. He says he's repaired a few of them, basically they grind the nut off and replace the bolt.
When I asked how I could have prevented it, he said "don't take the console off so damn much!" :icon_fryingpan:
watchluvr4ever May 17, 2011 08:15 PM
Keithhu, it is highly unlikely that you rounded that part of the bolt unless it is a poor quality bolt. It is more likely that the bolt shifted out of the slot just as it has happened to many others here.
Keithhu May 17, 2011 09:07 PM
Ok, could be. Either way, I'm going to pay them to grind the nut off and set it right, I dont have the time to f* with it, plus with my luck something more disastrous would result.
Big H May 18, 2011 12:01 AM
I have personally seen this on a couple bikes. Yes, the square head is a loose fit in some bikes and will spin if the console nut was tightened a few too many times. The best solution has already been discussed, protect everything and cut it off. Replacements are $5.
© 2026 MH Sub I, LLC dba Internet Brands
