Replacing the Tank Bib
Old 05-13-2011, 04:40 PM
ejvette's Avatar
ejvette
ejvette is offline
Default Replacing the Tank Bib
I want to replace my tank bib how do you get to the end that is under the dash console. I have an 09 deluxe. Just not sure how to remove the console housing.
Old 05-13-2011, 05:09 PM
DR. V-TWIN's Avatar
DR. V-TWIN
DR. V-TWIN is offline
Former Sponsor
Just loosen the bolt that holds the console on. No need to remove it.
Drew
Old 05-14-2011, 01:22 PM
oct1949's Avatar
oct1949
oct1949 is offline
It just slides in and out after loosening the console nut a little,
Old 05-14-2011, 02:11 PM
Sgt_Jim's Avatar
Sgt_Jim
Sgt_Jim is offline
First you have to get the bike on a jack and extend the front forks all the way, then you have to remove your seat, and remove your main fuse and disconnect the battery terminals. Once that is done, you have to disconnect your fuel line and make sure that there is absolutely no fuel in the tank. Follow this by removing your handlebars and grips and disconnecting all the wiring from the handlebars.
...not really.. just gotta loosen up the bolt that holds the console on, and if it's anything like my FatBoy, there's a Torx bolt under the seat that holds the bottom on..its something like a T25 or T27 sized Torx, and not even loc-tited on
Old 05-15-2011, 05:32 AM
ejvette's Avatar
ejvette
ejvette is offline
Dam.....could it be any simpler???? LOL!
Old 05-15-2011, 08:43 AM
SevenDLux's Avatar
SevenDLux
SevenDLux is offline
Sometimes I feel like doing anything requires this much effort.
Old 05-15-2011, 08:54 AM
JIMSFBL's Avatar
JIMSFBL
JIMSFBL is offline
I frikin spit my coffee!
Old 01-18-2017, 03:04 PM
Huggerbugger's Avatar
Huggerbugger
Huggerbugger is offline
Yeah well, I did all those things and it still didn't come off. So I made my wife do it.
Old 01-18-2017, 07:26 PM
rquest's Avatar
rquest
rquest is offline
Make sure the new one is good quality and has a felt backing or it will scratch your paint.
Old 01-18-2017, 09:36 PM
ILMFBL's Avatar
ILMFBL
ILMFBL is offline
You guys are so bad. You all know, especially you Jim, that you don't have to disconnect the battery and remove main fuse, just one or the other. Damn it Jim, you're not a surgeon!
Quick Reply: Replacing the Tank Bib
