brake lights, blowing fuses
Old 06-30-2011, 08:10 AM
speedstick's Avatar
speedstick
speedstick is offline
Default brake lights, blowing fuses
i have an 07 heritage, and now i keep blowing fuses for brake lights and signal lights,i have the kit that keeps the back lights on constantly
Old 06-30-2011, 08:47 AM
DR. V-TWIN's Avatar
DR. V-TWIN
DR. V-TWIN is offline
Former Sponsor
There has to be an exposed wire grounding on something metal somewhere. Last time I saw this issue the turn signals were twisted together and wrapped with electrical tape. The wore through the electrical tape and was grounding on the frame.
Drew
Old 06-30-2011, 09:24 AM
Hollywood Ball's Avatar
Hollywood Ball
Hollywood Ball is offline
I had the same issue a while back on my 09 Night Train. Pain in the ***. It was still under warranty but my local dealer couldn't track it down. They couldn't even replicate the short, but I could, almost every time.
I asked who did the test ride. It was some scrawny kid half my size. I mentioned the idea that it could be something under the seat, and maybe he isn't big enough to trigger it. They dismissed that idea.
Took the bike on vacation and to Charleston, SC with me (ya, in a trailer) and got fed up with the issue while there. Called Low Country HD and they said bring it in. By the time I'd gotten back to the beach house they'd called me to tell me they figured it out.
Turns out I had a loose ground connection causing the same short you are experiencing. Where, might you ask? Under the seat, of course, triggered by my fat ***, every time.
Electrical can be a pain in the ***, but check all your battery connections and ground connections.
Old 06-30-2011, 09:28 AM
colonelangus1's Avatar
colonelangus1
colonelangus1 is offline
check wiring under rear fender my brothers came loose and the tire wore a hole throw the casing and exposed the wires ..it kept blowing fuses.
vicsponjr
04-26-2017 08:48 AM
Pin it
03-08-2017 05:44 PM
travroc
07-22-2009 07:28 AM
seegs
08-07-2008 12:34 AM
Jaymz74
08-01-2006 11:23 AM
Quick Reply: brake lights, blowing fuses
