Ah! The screw driver puncture lever trick. Very good idea. I'll take it off that way. Thanks. Yes I've read about the sensor damage. Would someone please explain what a cutout on a tool which is OUTSIDE the oil filter has to do with something inside. I don't see any connection. The oil filter is symmetrical. The cutout does not go on any special orientation.
The cutout on the HD filter wrench really does work and provides just enough clearance to prevent sensor damage. To use it properly the wrench fits over the filter with the cutout oriented at the sensor. You then rotate the wrench, but not any farther than the cutout provides clearance for. Then you pull the wrench off the filter, rotate it so the cutout is re-aligned with the sensor, reinstall the wrench and rotate again. Repeat until you can spin the filter by hand. It works!
I can see if you have an cooler adapter on your housing the cut-out would come in handy. I tilt mine a bit and it slides between the filter and the sensor and doesn't touch anything. After its broke loose I remove the tool and spin it the rest of the way buy hand.
I use a strap wrench. Holds tight and does not get in the way of the sensor.
I will be using K&N filters from now on, since they have the hex-bolt on the end for easy removal. I put the filters on by hand, so they usually come off that way too.
