Clutch/lever question
So that being the case IMO U should adjust the clutch pac itself.
Here's how.
http://www.youtube.com/watch?v=k6Zdb...eature=related
Then readjust Ur cable nuts for correct lever play.
As far as the clunk, its normal that its a little louder in colder weather when the oils cold.
Also when starting Ur bike in gear it will want to pull forward, also when in neutral and on Ur lift the rear tire will spin. At Least all the bikes I worked on and mine does it and it's been said the same in here many times.
Wondering,, did U just change oils at the same time.??
My bike clunked more and shifted harder with I tired some 80-145 GL in the tranny.
I removed it a couple weeks after installing.
Went to Mobil 1 syn 75-90 GL and it made a big diff for the better.
