Question For X-Bones Owners w/Beach Bars
Hey Gang,
I have a question for any of you who own a Crossbones and have switched the stock mini apes for beach bars. For those who went with the narrow Crossbones beach bars: Did you change out your brake line, throttle/idle cables and clutch cable? If so, can you tell me how much shorter were the brake line and clutch cable that you switched to compared to the stock cables. For those that went with the H-D Wide Chrome Beach Bars: Can you post pics of how you routed your cables? I'm good on the wiring. I am interested in seeing how you dealt with the brake line and clutch cable. I am in the process of installing the H-D Wide Chrome bars on my Bones. According to the catalog, all my stock Crossbones stuff should work except for the turn signal wiring and mounts (which is not an issue since I am mounting my sigs to the forks). The throttle and idle cables worked just fine. So did the control wires (internal). However and have a feeling that my clutch and brake lines are a bit too long for these bars even though the book says I don't need to change them. I managed to route my brake line in a manner that works and doesn't look too bad but I think it would look much better if it didn't have slack. The clutch cable is a bit more of a challenge. I think I can make it work but again, I think it would be much better if it were a bit shorter. If any of you guys that went with the narrow bars could give me an actual comparison between the length of the stock clutch and brake line and the shorter ones you used I would really appreciate it. Thanks guys! Skeez |
I put Wild1 dresser bars on and didn't change any of the cables. I would think yours should fit without any problems, but if they are significantly wider than mine it may be close.
Beach bars
I put 37 1/2" bars on mine and had no problems. All cables fit perfect.
© 2024 MH Sub I, LLC dba Internet Brands
