LED headlight. My review (pic heavy)
Living in Colorado, it's not uncommon to ride some twisty dark roads full of big critters, so I finally bit the bullet and put the Harley LED light on my fatboy.
I had yellow laminex film on my stock headlight, so the first pics are lo/hi beam with the laminex on.
Second set of pics is the stock headlight (no laminex) lo/hi beam.
Third set of pics are LED lo/hi prior to aiming it. In these pics, the headlight was adjusted just as it was with the stock halogen bulb, which is to say, when I put my bike back together, I just eyeballed the headlight and called it good, I never officially aimed it.
Fourth and last set of pics are the led low/hi beam after a proper adjustment.
Stock headlight with laminex and no real adjustment. Lo beam, then hi beam:
Stock headlight with laminex removed. Still no real adjustment. Lo beam, then hi:
LED headlight out of adjustment (same adjustment as stock lamp in above pics. Lo then hi:
LED properly adjusted. Lo then hi:
It was a fairly clear, moonlit night tonight, which is why I don't think there seems to be a huge difference between lo/hi beam in any of the pics. Overall, it's clear that the LED lamp is far superior in all regards except one. The stock halogen lamp spills a lot of light outside of the actual beam pattern, which is kinda nice. The LED lamp is far brighter and crisper in the beam pattern, but outside of the beam pattern, there is nothing. That kinda sucks when you're in the twisties and you headlight isnt always lined up with where you should be looking.
I went with the "Truck-Lite" LED Headlamp that uses a "Reflector" backing (like the more traditional halogen headlamps) that spreads the lighting clear across a 6 lane Hwy.
Either way, the LED Headlamps are fantastic, I love mine. It makes night riding an absolute pleasure, and I'm glad for that. It's been so hot during the days, that I've only been able to ride at night.
