Replacing front fender on an FLSTC
I am replacing the front fender on my 07 FLSTC (dented) with one from an 04/05 FLSTC. I have two questions. (1) Is it necessary to remove the front wheel to change out the fender? Considering it's that nice humongous retro-style fender, I'm afraid I already know the answer. (2) Is there a trick for disconnecting the wiring for the fender tip light so you can remove the old fender? A hidden connector that I can't see? Or do you have to disconnect it from under the tank? Or cut it and splice it afterwards?
Thanks,
dta0251
Thanks,
dta0251
You're right, Rok... I found that out. After loosening the fender, I rolled it forward around the wheel and was able to squeeze the flared end just enough to get it past the fork tubes, which I had covered. On the new fender, the flared end was not as wide as on the old one, and it passed through the forks easily.
As to the wiring, I ended up just cutting it just behind the triple tree cover. I found that it was getting too taut when you turned the handlebars to the right, which I didn't like. So I'll figure out some kind of waterproof splice or connector and re-route it so it has a little more slack in it.
Thanks for the input... now on to the next project... replacing the fuel tank!
dta0251
dta0251
Thanks for the input... now on to the next project... replacing the fuel tank!dta0251
A pretty universal size for bike stuff is 3/16". Get it on Amazon.
Also removed mine for painting. I just cut the wire and respliced it.
A little tip for the fender--take a few newspaper pages and wrap & tape them around each fork just above the bolts. When you remove and replace the fender lift it just a little so that the paper protects the paint in case you mistakenly slap the sides a little.
