Frustrated with wheels. Please help!
When i bought my 2000 night train the previous owner put a rear deuce wheel and fatboy rear fender on it. I want to ditch the deuce wheel so i bought a rear spoke wheel off what i was told was a 05 fxst. It measures roughly 4" outside to outside to outside. So im not sure if thats right? I know should measure to th e bead seat. But itd still make it about 3.5? Anyway im basically trying to get back to a 16 inch rear wheel and get a 140 metzeler or so on it. But with this deuce wheel conversion done im not sure now what ill need to replace or how to check, spacers, belt, calipers etc. any insight would be much appreciate. Ive read a million post about doing the deuce conversion but eveyone seems to have different thoughts. Thanks in advance!
If it's off an 05 it will bolt up.I don't know about the caliper without checking a parts cross reference. Search on the forums here for one,it's pretty common. I will measure my stock spacers for you on my 05 when I get home tonight.I never switched one back either.You can get a 150 on there with no changes at all and a 160 with some bolt changes under the fender.I've been running a 160-16 on my Train for years.
There is a thread on here where a guy put a spoked Dyna wheel, 17X4.5 I believe on a softail, bolted right up, just had to change the bearings to the correct I.D. for his year (3/4 inch). Take a look for it. Look at this thread...
Dyna rear wheel on a Softail. Got questions?? Weelo88 figured it out.
I just took my stock 05 Night Train wheel off for a 200mm conversion. If you're interested in buying the Wheel/Tire/Pulley combo or need measurements or pictures...let me know. Complete rear fender with struts and light are also available.
It's all apart and easy to check right now if you just need help with what you have.
