Oil dipstick popped out while riding
My 2011 Heritage just had its 10,000 mile maintenance and since then put maybe 500 miles on it. Today the dipstick came out and covered us and the bike in oil while riding. The oil was at the full mark and I always check it when its hot. Just on a usual ride and maybe kicking it a little hard. Any similar experiences....
Two things that make the dip stick come out, too much pressure in the tank and the seal wore out on the dip stick.
Engine blow by can cause too much pressure, blocked breather, bad umbrella valves, clogged breather line also too much oil and the tank does not have enough air in the top, and does not breath right.
For the bad seal on the dip stick I have added a o-ring.
As one of the other fine folks said, it seems that our bikes like the oil level around mid point between full and low on you dipstick. To the top of the full mark when hot is TOO MUCH...doesn't seem like it should be, but it is...many of us have confirmed this HD "feature"...LOL. But the fix is easy, 1/2 way between full and low and you should be good to go. Good luck.
