Splicing 3 wires together
Old Aug 26, 2013 | 02:59 PM
DC_Night_Train's Avatar
DC_Night_Train
Default Splicing 3 wires together
I bought a side mount license plate a while ago. I used the tap that came with the part to connect the license plate's light lead wire to the run wire of my brake light. The lights on the license plate have been acting up and I think I have a connection problem.
I wasn't too happy with the tap that came with the part but it worked so I rolled with it for a while, but I think I need to redo the connection. I am thinking about cutting the brake light's run wire, and splicing the 3 wires together. What's the best way to go about this? I've been doing a fair amount of reading and it sounds like there are a number of methods. Solder, cap, crimp style cap, or a hand twisted splice covered with silica. What have you all done for projects like this? Thanks
Old Aug 26, 2013 | 03:08 PM
im's Avatar
im
Ever consider a posi-tap?
Go to link and scroll down to posi-tap.
About $10 with free shipping for 7 piece assortment.
Clean,easy & reversible.
see video at bottom.
http://www.webbikeworld.com/sale/pos...s-for-sale.htm
Old Aug 26, 2013 | 03:45 PM
Raddazzz's Avatar
Raddazzz
I have soldered and heat shrinked wires plus just twisted them and heat shrinked depending on the application and the wire exposure. If you have never soldered wires is does take a little practice plus the area you solder wont bend much after your done.
DC_Night_Train
Damn. Thanks man. That posi tap would have saved me a ton of trouble. Have you used any of their products. Cool that they use it to keep the site up and running too.
Old Aug 26, 2013 | 03:46 PM
DC_Night_Train
Thanks Raddazz. I've never soldered before so I think I might go another route on this project.
Old Aug 26, 2013 | 04:30 PM
samplefool's Avatar
samplefool
Solder and heat shrink are the best option for a connection that will be exposed to the elements over time the posi tap will prob rust up.
Old Aug 26, 2013 | 04:40 PM
UT-rckr's Avatar
UT-rckr
Practice soldering. It will come in handy in the future too. I solder all my connections on my bike to make sure they will hold up over time.
Old Aug 26, 2013 | 05:29 PM
kneesinthebreeze's Avatar
kneesinthebreeze
I used these on my LED license plate bracket and they are brilliant. Best thing for splicing thin wires.
Old Aug 26, 2013 | 05:51 PM
Midgard's Avatar
Midgard
They're perfect for motorcycle use because they don't rust, they're not bothered by vibration or heat, they're dustproof (and some are waterproof) and they can be used over and over
^^ from the site
Old Aug 26, 2013 | 06:53 PM
jam436's Avatar
jam436
^^ from the site
Amen, these came with my Custom Dynamics LED turn signals, for use with the Can-Bus adapter - they've been on for about 6 months without issues.
They go on easy, they seal and they stay tight.
What more could you want?
I'd definitely use them again as opposed to cutting and soldering...
