Trade Dyna Wide Glide front end for Softail front end
Would like to trade my 2012 Dyna Wide Glide 49mm front end for a Deuce 41mm Front end. I might be interested in other Softail 41mm front ends as well. I'm planning on cutting and modifying my frame, and I'll need a front end that I can extend. I can only get 8" over stock length tubes for my 49mm, and I'll need to go more than that so I would like to get a Deuce front end to extend. I'm in Wichita KS, 67204.
Will the dyna front end bolt right up to the softail frame? Do you know if the front wheels and spacers will still fit? I have a 2008 night train with 41mm front end i might be willing to trade with you on, but need to make sure it will fit and the wheels spacers will also. I have an aftermarket front wheel so dont want to have to give that one up.
I have a 25mm front axle, NOT a 1" axle. If yours is 25mm, then the wheel will work. You might need different spacers. I can make mine on my lathe, but you can buy spacers in a lot of different sizes or have some made. The trees will bolt to your frame with no issues, but you will probably need to do some mods to your fork stops to limit the turning of the front end.
