Cleaning Machined Cooling Fins
And yes, it is a slow process. All total I think I spent about 3 days on mine. Just keep the beer close and stay patient..
Yes, I ran the polishing wheels parallel, along the length of the fins when using the retangular wheel. Used the radiused portion of the ball and held the Dremel at about a 30 degree angle. I used a moderate pressure and then went to a light pressure for the high polish. For the high polish I also increased the Dremel speed a bit. I worked about a 1 to 2 inch section at a time.
If you'll PM me your email address I'll send you the full instructions in a word file. This thread is a little broken up as far as instructions, and I put together a much more organized versions, with pictures, in word. Don't use that big wheel because it's too flexible and hard to control. The one I call rectangular is the one you are showing next to the polishing ball..
Just wanted to bump the thread and ask how did with it?
I myself just had a new rear tire put on and afterward the dealer washed the bike. Of course I road 25 miles back to the house. When I got home I noticed that my fins were terribly spotted from the wash. None of the normal bike cleaners would take the spots off. I pulled out the aluminum restorer, worked some into a soft cloth and polished away by hand. The spots came right off and the fins are as bright and shiney as the day I finished them. Only took about 20 minutes to do the whole thing..
What can I say......wow!
Thanks so much, this was exactly what I was looking for !!:ic on_clapclap:
Pitbull_Dallas (04-15-2017)
Any other suggestions out there? She is a gorgeous gem otherwise. The oxidized fins are a real turn-off.
32vld
06-24-2011 12:24 PM
