FatBob Headlight on Breakout with Dual LED
Here are the new images.....
Ok, so this is my new project. I figured I would throw up some info and part numbers for anyone else who wants to do this.
First, I have to give credit for the idea to boosting1bar, he has already done this on his FatBob, and was going to make more mounts for others, but he is having trouble finding a cost effective source.
https://www.hdforums.com/forum/dyna-...p-on-fxdf.html
I took a slightly different approach.
Here is the list of parts, and quantities needed.
(1) 69798-08 HEADLAMP SHELL ASSEMBLY
(1) 69801-08 TRIM RING (chrome) or 61400181 TRIM RING (black)
(1) 68000008A DAYMAKER AUXILIARY 4" LAMPS, BLACK
(1) 69839-08 BLOCK mount
(1) 4762 SCREW 3/8-16 X 4-1/2 hex hd. (Grade 5)
(2) 6701 WASHER 3/8 X 13/16 X 1/16
(1) 7775 LOCKNUT 3/8-24 X 7/16 X 9/16
(2) 3159 SCREW #8-32 X 1/2 flat hd
(1) 73154-96BK HOUSING 4-place socket
(2) 73191-96 TERMINAL socket, #16-20 AWG
(1) 72298-95 CABLE sealed (green)
(4) 72356-95 TERMINAL #18-20AWG (HDI)
(2) 72161-06 HOUSING 2-WAY socket Female Black
(2) (NOT HD PARTS) Metal ring .125" x 4.16" ID, 4.70" OD
I'm pretty sure that is everything. I bought the headlamp shell, trim ring and wiring harness off ebay for cheap cause it was slightly damaged. The only other thing I used that is not a Harley part is 2 aluminum mounting rings I had made. You can see them in the first image. They are .125" with an inner diameter of 4.16" and an outer diameter of 4.70". I had to clearance these for tabs inside the headlight housing, as well as tabs on the lights. An angle grinder and a few minutes took care of that.
hmmm.... wonder if theres someone else making an led for those.... ON THE HUNT!
BTW, there are other LED's that should fit. You can get High/Low ones as well. Be warned though, they are not cheap.
JW Speaker 6130 http://www.jwspeaker.com/products/he...-4-5-round.pdf
JW Speaker 8415 http://www.jwspeaker.com/products/headlights/model-8415-45-round-led-low-beam-headlight
