HD sissy bar assembly for Breakout
For those wondering about how the HD sissy bar offering for the Breakout (there is only one) looks like on the bike, when equipped with the quick detachable side plates, here is a photo:
http://i252.photobucket.com/albums/h...ps1a831d55.jpg When you take it off, here is what it looks like (notice that the only artifacts are the "spool" mounts, which replace the fender support bolts): http://i252.photobucket.com/albums/h...psb40a2eab.jpg The process of getting the entire assembly "on" or "off" the bike takes at most 5 seconds, once you understand how it works. I went fancy on mine: the sissy bar, quick detach chrome angle-adjustable sideplates, "french seam" sissy bar pad, and I have the "lock set" on order that will lock the entire assembly to the bike, but release quickly via the provided barrel key. I realize there are at least some other choices in the aftermarket, but for a factory HD product, this setup seems pretty good. Jim G |
Thanks.
Nice looking Breakout. What pipe is that? |
Originally Posted by 2807
(Post 12801157)
Thanks.
Nice looking Breakout. What pipe is that? D&D says the Low Cat is the designated exhaust for the Breakout - it does not list the Fat Cat as fitting the Breakout, because of the ground clearance issue. The stock Breakout has very limited cornering clearance compared to most HD models (only about 24 degrees as I recall). In addition, my specific Breakout has also been lowered further another inch at the rear. Jim G |
nice looking bike. I was looking at some of the options as my wife has been wanting to ride and I don't feel comfortable taking her along without a sissy bar.
I really like the fact that there is very little left on the bike when you remove it. |
Originally Posted by JimGnitecki
(Post 12801047)
I went fancy on mine: the sissy bar, quick detach chrome angle-adjustable sideplates, "french seam" sissy bar pad,...
... and I have the "lock set" on order that will lock the entire assembly to the bike, but release quickly via the provided barrel key. |
Originally Posted by PikeAl
(Post 12801811)
I really like the fact that there is very little left on the bike when you remove it. When touring, I carry only about 15 pounds of luggage, and it will go into an HD roller-and-handle-equipped touring bag, that will secure to the sissy bar via an elasticized band (see the HD webs tire for details on that roller equipped bag). When touring, and when staying in one area more than overnight, I will be able to completely remove the sissy bar within 5 seconds, for local riding. I have the lock set coming so that no one can steal my quick detach side plate-sissy bar assembly while I am inside a restaurant while on tour. The lock set is very slick. It replaces the two pieces that hold the assembly onto the bike with similar pieces that have barrel locks built into them. This means that the appearance does not change at all with the locks having been added - you have to look closely to even see the holes for the keys. To get part numbers to duplicate this assembly, go to the HD website, select "2014 Breakout" as your filter, select the sissy bar and back rest category, and you will then see: - The sissy bar - The sissy bar pad - A selection of "quick detachable" side plate sets, in either chrome or powder coated black, that are either "fixed angle" or "adjustable angle" for the sissy bar mounts - The "hardware kit" that replaces the fender support bolts, and allows you to quick detach the entire sissy bar / side plates assembly - The locking quick detach kit that adds locking capability to the quick detach side plates. Jim G |
Originally Posted by FurryOne
(Post 12802081)
One thing I've noticed with that pad - it is a bit too thick and tends to almost push your passenger off the wider section of the Sundowner pillion. It could use about half as much padding.
:icon_idea: Jim G |
I ordered one from ginz, still 4 weeks out
Jim G... your Breakout is one hot looking scoot my friend. Good Job.
To any other Breakout owners, I have the exact same one as above, but PC black with the HD logo on center of backrest left chrome. If anyone wants to do a straight trade for a chrome one I'd be willing. The black just didn't work for my bike, but looks great. I barely use it and brand new. |
I'm really surprised that HD did not come up with one specific to the FXSB or FXSBE tht fits the bike lines better. Was looking to have a low sissy bar made up for my Breakout like the 2013/2014 FXDWG - one piece, low, clean black bar. or maybe fab up one that mounts to underside of the passenger seat and looks like the one for the VRod. Wifee needs something to hold her on, at least something to lock in that booty :D
Anyway if I get something done I'll post up pics / info. My scoot: http://www.808networks.com/pub/hb4b.jpg |
© 2024 MH Sub I, LLC dba Internet Brands
