Shock adjustment problems for soft tail.
Old Jul 5, 2014 | 09:13 AM
scriv's Avatar
scriv
Originally Posted by Tracker56
The shaft shouldn't turn with the adjuster, if it does, you probably need to spray it with some PB Blaster or other penetrating oil, let it sit and then use a 9/16" wrench on the flats on the shaft to hold it. It should break loose and turn for you after that.
Thanks. I appreciate it. I got it this morning. I put the wrench on the flats like you said, they came loose easily. No sweat after that. Easy business. My whole issue was due to the shocks being backed off all the way to begin with and not knowing it. Ride on.
Old Jul 5, 2014 | 02:07 PM
tmitchellof PG's Avatar
tmitchellof PG
When you have your shocks adjusted fully one way or the other, in the same direction, paint a white stripe on the bottom of each shock going forward/aft. That will make it easier to count the turns so you can adjust each shock the same amount.
Do not tighten the jam nuts very tight. I have never had one loosen between adjustments and it feels like the jam nuts tend to get tighter between adjustments.
If you adjust the shocks either direction all the way, back them off a hair before you tighten back the jam nut. The shocks wont be jammed into place the next time you adjust them.
I had to use my dremel to grind a 1" open end wrench out to a 1-1/16" to fit the jam nuts. then I cut the handle down to about 4" long.
My bike is lowered an inch in the rear and that gives me room to move the wrench while the bike is on the jiffy stand.
Tom
olskoolblu
Jul 4, 2013 08:13 AM
CT-Mike
Jun 25, 2011 01:51 PM
Mr. Lucky
Jan 22, 2009 08:17 PM
Whiffleboy
Aug 25, 2006 04:24 AM
scooterbooter
Jan 2, 2006 01:36 AM
