Suspension issue - need guidance
I've never really understood suspension, so I need to ask for some advice.
My 2014 Breakout got a $70 lowering kit for the rear suspension as part of the new bike deal, and is lowered about 1 inch. I'm sorry but I cannot recall the name of the kit. I might recognize it if I heard it.
I knew when I bought the kit, that it would take out some of the available suspension travel, but have done similar things on prior bikes and the results have been good. Great look and no notable loss of comfort.
This time is different.
First, the seat on the Breakout is rather thin to begin with, to get that "slammed" look that HD was shooting for. Then, I needed to go to a "Reach" seat to stay comfortable for long distances (up to 50 miles was fine with the stock seat, but after that, some aching in my lower back). This made the seat padding even thinner. This make the suspension a lot more important than it was on prior bikes.
The problem I am having is very specific. It occurs wherever there is a "ridge" in the road surface (e.g. a new layer of pavement starts, or there is a chunk of surface pavement "missing"). In such cases, I experience a jarring that goes right up my spine.
Adding a gel pad helped a bit, but did not solve the problem.
I'm thinking that the suspension needs adjustment. To my knowledge, the only change the HD dealership made to the suspension before delivery was the lowering kit.
With my riding safety gear on, I weigh in at about 230 lb.
When I hit one of these ridges - and I'm talking some pretty shallow but ABRUPT ridges - I feel a strong sudden shock, but it does not feel like the suspension really moved very much. There is no sensation of suspension movement and then "bottoming out". It is just an immediate "jarring" as though the bike has no suspension.
Another potentially important clue: The one time (so far) that my wife was on the bike as a passenger, the suspension felt BETTER. I don't recall feeling a single ridge that time.
Is the suspension travel simply too little with the lowering kit, and am I actually bottoming out? Or, is the suspension simply too STIFF, and therefore causing that jarring?
What is the correct cure?
p.s. please no suggestions to buy a Shotgun air suspension. I just won't accept any air-based solution, because WHEN the air suspension develops a leak, you are stuck with a fully rigid bike for whatever distance to home or a dealership, and I won't accept that. if such air leaks were truly rare, I'd consider air suspension, but I see way too many instances of leaks. I want a suspension I can forget about.
Jim G
Jim G
when using stock shocks i think lowering is usually a sacrifice on comfort & handling for looks... Softails have limited travel already, and lowering shortens the travel even more.
you can try adjusting the preload... Less preload its bouncier and can bottom out.... More preload its more harsh (can be harder on the spine).
i'm slammed as far as my kit would let me know (prob about 2"), once i sit on it there is very little travel left (and on a hard enough hit the little bit that is there gets stopped when the tire hits fender). it rides like a rigid, but slightly better (you feel every little tiny bump).
i think the only real options are either air ride or a more adjustable expensive aftermarket set of shocks like progressive or Olins or something similar that have more adjustments for length, preload, & dampening... or just deal with it and ride it as is.
Ohlins don't do softail suspension anymore (real shame) and the progressive 422 is a little better than stock and is adjustable for height and preload.
I've only had my 422 RAPs on for week or so but I can assure you they are a lot better than stock.
That being said, everyone's entitled to their opinion.
At stock height, I agree. Their is room for improvement, but much better then stock. And given the price point, a very good option.
