Mark this thread as Unsold
Harley Rocker Big Radius (black)
Set of Vance & Hines Big Radius for a Harley Rocker with BCT Monster baffles Part #2002. Powder coated the heat shields gloss black. I'll send the old clamps with them but you should buy new ones.One very small scratch that you can barley see at the end of one of the pipes. I've read that the gloss holds up good and I've heard that they will fade. My powder coat guy says the ones he has did so far have stayed gloss. I bought them to try and fit them on my Breakout but they don't fit. If you make a new bracket they would probably fit.
$380 shipped in the US.
The pipes bolt up to the motor fine and looked right. But the rear bracket is different. The 02 sensor on the front pipe is higher up on the pipe but fits. You would need to get the 12mm reducers (it has 18mm bungs on these pipes). I got a good deal on another set of Big Radius that fits my Breakout. I compared them. The exhaust looks the same. The back bracket on the Rocker pipes sets out farther from the frame than the Breakout bracket. The Rocker bracket almost works with the front pipe but did not want to force the bolts and holes to align. The Rocker bracket made the rear pipe stick out and the bolt holes would not align. With the right rear bracket or modify the one that comes with the pipes they should fit. I don't have access to the tools to do this. Below is a pic of the Breakout bracket on my bike. Don't know if you can see the difference between it and the picture of the bracket above.
Back up for sale. Got the one exhaust shield that had a scratch in it re-powder coated. So shields are in perfect shape. $275.00 plus shipping.
