Custom swingarm for wider tire
Since nobody else has pointed you to it, here ya go - Tzrider's 180 thread putting one in a stock swingarm.
Thanks! I read through every post in that thread. Good info.
The Superlow does indeed have a 17x4.5" rim. After taking a good long look at all the spacing around the tire, it sure doesn't look as though there's much room for a wider that's too much wider.
Someone mentioned the need for a possible belt pulley and sprocket spacer. I think 1/8" or 1/4" might be all I need to fit a 170 or 180 on the back. Where do you find those spacers?
You can find those spacers on Ebay, which is where I have bought mine. What a spacer does is to move the pulley away from the wheel and towards the swingarm. So the maximum width of spacer you can use is less than the gap you currently have between the two, otherwise the wheel won't go back in!
You would need to add a spacer for both sprockets right? Do they come in matched pairs or sets?
Something like this??
http://www.ebay.com/sch/i.html?_from...pacer&_sacat=0
