HD 48, where to start with customization, and what?
Great recommendations. Workshop manual is the best investment to make followed by anything that will make you more visible on the road... Custom Dynamics LEDs for the turn-signals/brake lights would be another must-do mod.
Stock rear shocks can be replaced by take-offs from an RGC.... but you will find that the ones to really replace are the front ones... I hated the stock dive the bike took every time I hit the brakes. So I would do those first and then keep an eye in the Touring forum or the roadglide.org forum for some used rear shocks (if you are on a budget).
Speedo location? You have the best speedo setup location there is... do not mess with it. Ask me how I know... I moved mine only to put it back in its stock location.
Have fun with your ride. Best part of all this, besides riding, it making the bike yours with the modifications made.
In addition consider using an add-in damper unit, to improve control. I have Emulators in my Sportster, although I can't recommend them, so have a set of Intiminators to install in my Glide, which get good reviews over in the Touring section.
I suggest you consider replacing the stock fork springs with single rate ones. Race Tech make them in several different ratings, so you can match them to your weight. That should reduce dive, also by setting sag correct give you more suspension travel to ride on.
I also have a 2014 48 and have done just my stage one upgrade so far. The pipes on a 2014 48 are incredibly simple to change. It's all just about undoing/redoing a few bolts and you're done. While it's incredibly simple it's not necessarily incredibly easy. It took me probably 30 minutes of prying my stock mufflers back and forth before they finally loosened up and came off. Patience and elbow grease while not overdoing it and tipping the bike over is the name of the game.
Also did an Arlen Ness big sucker shortly after. That should have been simple but the instructions are terrible. They send a one sheet page that is like a copy of s copy of a copy- very noisy visual/hard to discern pictures. They also do a very poor job of identifying parts that are sometimes very similar to other parts you won't actually use in the installation, which can add some confusion. One you are comfortable that you've sorted out what's what, installation becomes easier.
I personally think that as soon as you are confident that you know what you want and you have a look that you know you want to achieve, start modding away. The only thing that's more fun than riding a new harley is riding a new harley that sounds the way you expect a harley to sound, because bone stock is not that.
After purchasing my superlow 2 months ago I immediately wanted to rush out and spend a heap of money but decided that I would ride it a little and get an idea of exactly what I wanted. I've now put over 2000 kilometers on the bike and things that I first throught would bother me no loner do, and other things have moved up the list. I'm going to start collecting pieces shortly and one of the first things I change will be the grips.
The only thing that after riding I decided I didnt want was mid controls.
Very smart!!!...;-)
