steering
Old Dec 27, 2014 | 09:46 PM
michaelharris376's Avatar
michaelharris376
Stage II
Default steering
I was in wreck hit gravel and slid out on me. bent bars. Got new ones put them on now when going down road when looking down it looks like handle bars are pulled back on one side what else could it be . Could it be the upper triple tree?
Old Dec 27, 2014 | 09:49 PM
scooter1128's Avatar
scooter1128
check your riser and riser bolts
Old Dec 28, 2014 | 07:27 AM
Kenny94945's Avatar
Kenny94945
You need to check the entire front end.
Could very well be just the risers and bolts as suggested above.
Easiest is to loosen to the front axle, front fender and all the triple clamp bolts to reset the fork alignment. Make note of the front fender bracing to the lower fork tubes; if the fender is bent it could prevent this reset.
If that fails, next is to look for something bent. Typically fork tubes, lower triple clamp with stem. Could also include upper triple clamp, damaged head bearings, fender, axle, steering stop tab on the frame.
There is probably more, yet above could get you started.
Best of luck.
FireFighter200
2014-2024 Touring Models
Mar 10, 2016 12:19 PM
dbeach2014
General Topics/Tech Tips
Mar 4, 2015 01:34 PM
AlexVDL
Feb 6, 2014 10:29 AM
GlobeWarmer
Aug 12, 2013 02:02 PM
Hey Zeus
Ironhead
Jun 15, 2006 12:04 AM
