Stock muffler baffels
I did this mod on my 2013 '48.
I really enjoy this guys videos.
A 1/2" hole in the center did sound better and no power was lost.
Actually picked up a little mid range power improvement.
I then thought to my self , why not go bigger?
Next I drilled them out to 3/4" and they sounded pretty awfull , a "squirt" kinda sound was present that bugged me.
I went further afterwards , but that's another thread.
The 1/2" sounds pretty good and won't drive your neighbors crazy.
Best thing is you don't have to remove them to do this mod.
Mick
Mick
Received 3,931 Likes
How to Modify Stock Harley Mufflers! - Iron 883 | ShopTalk - YouTube
Mick
Mick
About 90% of the shavings go towards the rear , I just let it idle for a few seconds to clear the rest.
You could do better to put a dab of grease on the drill tip and probably get more control of the chips.
What I did find eventually is that a 1 3/4" hole saw allows the removal of the complete baffle assembly if it's a non catalytic muffler.
This creates a standard sized exit port which doesn't produce the blast that a larger hole will make , allowing for some resistance to flow.
The 1 3/4" hole would enable someone to use a small TTI and have more control over the flow and sound as opposed to a gaping exit when done.
Mick
Mick
Mick
Mick
My concern is that reversion is a strong force. Wouldn't want any metal dust getting back up to the exhaust valves. Probability is very low, I just tend to error on better safe than sorry.
