running like crap
running like crap
I have a 08 xl1200c. I have short open drag pipes, screaming eagle heavy breather and thundermax ecm installed. My bike is running very rich. Black smoke out of exhaust, check engine light is on and codes p0151 and p0562. I've swapped out the o2 sensor and it still runs like **** and puts out the codes. I'm not really knowledgeable about the thundermax software and the technical support there is crap. So I am here asking you fine fellows...... any suggestions?
Ok this is kinda long and strange. Bike ran great, no problems. Then took it apart for paint. Just rear and front fender, tank and side covers off. Was off for about a year waiting for paint. Had some kids jacking around with it a few times. Found some broken wires in the back area with the lighting. So put bike back together with new paint job. Bike ran like **** thereafter. I know from 22 years of aircraft maintenance that if you leave something ****, things are gonna break. But airplanes and motorcycles are 2 completely different animals.
Not entirely, both have wiring, connectors prone to corrode if exposed to elements, so on.
I suspect you may have a wiring/connector issue. I'd unplug/grease/plug-back all connectors, even those hard to access behind electrical panel in battery compartment and under fuel tank. While there I'd inspect everything closely for physical damage.
JKH16
09-30-2015 06:39 AM
