Jimmy's Forty-Eight
Old 11-05-2015, 09:34 AM
Bryan83taco's Avatar
Bryan83taco
Bryan83taco is offline
Looking good man
Old 11-08-2015, 10:16 AM
jimothy cricket's Avatar
jimothy cricket
jimothy cricket is offline
[QUOTE]
Originally Posted by BensonUK
I love the Sportster, how many other bikes can have so many looks and still look good!
RIGHT!??!!
Originally Posted by kingxirol
Looks awesome!
Thank you good sir!
Originally Posted by Bryan83taco
Looking good man
Right-on, homie.
Enough of the sh*tty iPhone pics...went out yesterday and shot the bike. Same-old same-old.
The following 2 users liked this post by jimothy cricket:
45ACP3% (03-05-2016), Hanover Fiste (04-20-2017)
Old 11-08-2015, 11:33 AM
Sweforty8's Avatar
Sweforty8
Sweforty8 is offline
[QUOTE=jimothy cricket;14557817]
RIGHT!??!!
Thank you good sir!
Right-on, homie.
Looks really good man!
Old 11-16-2015, 07:06 PM
jimothy cricket
[QUOTE=Sweforty8;14557983]
Thanks!
Old 11-17-2015, 11:16 PM
siik2nr's Avatar
siik2nr
siik2nr is offline
What did you use to remove the tank paint?
Did you treat it after you removed the paint or just letting it rust?
Old 11-19-2015, 08:28 PM
jimothy cricket
I used paint stripper from a yellow aerosol can I got form ACE Hardware (Can't remember the name)
I had to apply that about 3 times, scraping the paint and clear coat off each time in between sprays.
Then I finished it off with a wire wheel on a power drill. It added some swirls to it which I didn't mind...but you could always go over it in a directional motion with some sandpaper.
Currently it's uncoated...It gets some surface rust and I just hit it with sandpaper again to eliminate some of that. I heard WD40 helps prevent the rusting, but I've just been too lazy to try that.
Not sure if I'll clear coat over it or paint it at some point
Old 01-31-2016, 06:05 PM
jimothy cricket
Since winter has arrived in the Chicago-land area, I've taken time to do some things.
I did a wire tuck, so really no wires are shown near the or around the engine, except for the gas lines and what not. Here's a before and after:
I also picked up some solid brass grips, pegs, and headlight bezel. Not sure that i like the seat and tank with hints of brass now, so I'm taking time to think about replacing them or not.
Here you can see where I relocated the ignition for extra-stealthness
Old 02-02-2016, 11:32 AM
J's_48's Avatar
J's_48
J's_48 is offline
6th Gear
That looks sweet!
Old 02-02-2016, 01:03 PM
jimothy cricket
Originally Posted by J's_48
That looks sweet!
Thanks, J!
Old 02-03-2016, 04:40 PM
huyrua's Avatar
huyrua
huyrua is offline
Very clean bike, awesome job
Can you give more details on the ignition relocation, it looks very stealthy.?
Quick Reply: Jimmy's Forty-Eight
