Calling all dual front disk sportster owners
Good evening everyone,
I am currently in the process of gathering information to convert my 2014 Iron 883 single disk front brake to a dual set up off of a 2014 roadster. The question is, why are the part numbers different between my Irons left lower fork slider and the roadsters left lower fork slider?
America's part number for left lower slider (45500054)
Europe's part number for left lower slider ( 45500055)
Everything i can find online points towards them being identical.
Are they both the same color gloss black? Is one a different shade black than the other, which would warrant a different part number?
The reason i'm comparing the left sliders is that the right sliders will definitely have different parts numbers, because of the casting for additional caliper mount.
Thank you in advance for any insight you can provide me with.
Received 2,189 Likes
http://www.ebay.com/itm/NEW-08-AND-N...970631?vxp=mtr
i got them for 135+15 shipping.
https://www.hdforums.com/forum/sport...c-sliders.html
I have a 1200c I put a 19in wheel up front, 1200r fork leg (rt) and vrod front calipers, 1200r brake line and m/c.
I make the brake lines changeable so in the future if I change the bars I just go back to the hose shop and have a longer top pice made... Instead of having to buy a WHOLE system!
It stops soo well way better than stock!!!
I've finally gotten some answers regarding the part numbers I listed in my opening post.
45500054 ( 2014 Iron 883 GLOSS BLACK) left lower slider
45500055 ( 2014 883 Roadster FLAT BLACK) left lower slider.
If you want to use new OEM parts you either need to order both 45500055 and 45500076 flat black sliders.
Or order just the 45500076 and have a clear sprayed over the flat to have it match the gloss finish on the left slider.
Here's the parts I used for my OL's '13 Iron. You dont need to do everything
I did, but you'll have to come up with replacement parts if not...
593-03-M12CH Goodridge banjo bolt 30 degree
XL Roadster right hand side fork slider 46449-08 ~$139.00
XR Master Cylinder : 42941-10 (15.87mm bore DOT4 M12x1.5 banjo) ~$95.00
Master Cylinder clamp 42808-04 ~$10.00
Fork seal kit 49378-09 (I did both forks,used two kits) ~$36.00 each
41737-04 12mm bolt
41736-04 10mm bolt
EBC FA296HH pads for XR1200 calipers 2 sets ~$40.00 each
XR1200 Left Caliper: 42943-08 ~$153.00
XR1200 Right Caliper: 42944-08 ~$153.00
EBC contour rotors FSD006CBLK 2 required, ~$190 each
Goodrich black stainless brake hose (M/C to tee) 1 @ ~$32.00
Goodrich black stainless brake hoses (tee to calipers) 2 @ ~$25.00 each
Russell tee block (dont have part number)
hope this helps,
T.
41737-04 12mm bolt
41736-04 10mm bolt
hope this helps,
T.
