Coldest Sportster ride?
Received 2,189 Likes
2002 Sportster 1200 Custom.
20 degrees
Bike ran fine and I was surprisingly warm as I took an old pair of chest waders that had a leak and cut the feet out. Pulled a pair of jeans over them, put on some extra layers and insulated boots and rode around town.
Folks seeing me in a pair of jeans were giving me the all over town.
Hardest part was getting my leg over the bike as neoprene doesn't flex too well.
20 degrees
I started winter riding in the winter of 56/57 to HS and my after school job to pay for the bike.
Last winter I did 9,740 miles from Nov. 1 to Mar. 31st. This year I am just past 7,000 miles so far.
I have learned the number of layers that I need in each ten degree increment from 10 up. The lower the temp the shorter the ride of course. But 1 hour is my lower limit for teens, 2 hours for twenties and three or more in the mild thirties. Daylight becomes an issue in winter riding so I can't stay out too long. I don't like riding in the dark.
I do have heated gloves and wind protectors on the handle bars.
The Sportster or any bike do not suffer from winter use at all. I just clean them in the Spring. They do dry out in a heated garage after the rides.
H-D's are not fragile delicate instruments. They are rugged machines to be used not pampered.
Oh! I almost forgot. If you run an oil cooler on your Sportster and winter ride. Cover that sucker up. There is no thermostat in the Sportster cools like the rest of H-D's line so below 40's the engine will not warm up enough to go off the enrichener and will burn a lot of extra gas.
What did you decide and if you bought it, how was the ride? I'm not that experienced with cold weather riding but went out yesterday and learned the importance of layers, something on my neck, that hands/fingers get cold even with Winter gloves and that stop and go traffic in town at relatively low speeds is a lot more comfortable then a faster, generally more enjoyable cruising speed.
Good luck with whatever you decided.
