Go Back  Harley Davidson Forums > Harley Davidson Motorcycles > Sportster Models
Reload this Page >
2005 Harley sport xl1200Runing on back cylinder front kicks in while riding on high rpm
Notices
Old 03-03-2016, 04:28 PM
Afshin Delfanazari
Afshin Delfanazari is offline
New Member
Unhappy 2005 Harley sport xl1200Runing on back cylinder front kicks in while riding on high rpm
Hi all
Please forgive me for bad grammar and newbie questions.
So I have a 2005 hd sportser 1200 with about 16000 17000 miles on it just bought it for $2500 might of screwed my self on this one for sure. When I bought it I couldn't ride it or hear it idle more than 2 minutes as I bought it at late night and bike is loud as hell. Come home take it for a ride I notice bike is runing like ****. When I took it for a ride down the street at 1/4 bike barely moved then anything after that the other cylinder kicks in then this thing moves like I'm about to get thrown off love it love it love it. But bike is runing bad idle one cylinder is not working the whole time.
1. So I checked the front spark it was black cleaned it spaced it replaced the two with each other problem didn't go away.
2. Then I put a spark tester on notice rear cylinder light up bright and powerful so I tried the front one not so bright and pretty weak spark coming out of it through the tester. Switched the wires and nothing still weak on front cylinder before the spark plug.
My question is!!? Is this do to bad coil? Or bad position sensor? That doesn't send good signal? Bike off I get .68 or 6.8 on each end before the coil.
I change the wires from front to back and bike just back fires out the exhaust and never starts I'm guessing my bike doesn't have both fire at once!! And bike runs bad like crap while idling lot of spitting and back firing idle.
My real question is!! Is this do to coil? Or is this do to bad wire? Or is this do to bad position sensor? Or is this do do bad jets? I'm really confused what to fix first and no go broke all at once ) so please any help I appericiate greatly.
PHP Code:
[IMG]https://cimg8.ibsrv.net/gimg/www.hdforums.com-vbulletin/2000x1504/80-image_c8cfd52c8c60eb716dc588020692bd47001ad7ea.jpeg[/IMG]
" border="0" class="tcattdimglink" alt="" />" border="0" class="tcattdimglink" alt="" />" border="0" class="tcattdimglink" alt="" />" border="0" class="tcattdimglink" alt="" />
Plz help lol, I'm good with cars I understand the logic but this bike thing I'm new to.
Old 03-03-2016, 08:10 PM
Von_Zipper's Avatar
Von_Zipper
Von_Zipper is offline
I'd check compression.
Old 03-03-2016, 09:23 PM
hpotter
hpotter is offline
One Of The Regulars
does not look like a 2005 sportster to me. try to swap the two ignition cables...
Old 03-03-2016, 09:56 PM
cvaria's Avatar
cvaria
cvaria is offline
Received 2,067 Likes on 1,593 Posts
Agreed, triple part rockers, oil tank, frame, rear brake placement. 2003 down.
Old 03-03-2016, 10:55 PM
JustOneDean's Avatar
JustOneDean
JustOneDean is offline
Yeah, that looks like a solid-mount engine. Check the VIN, tenth digit will tell you the year. It doesn't sound like bad jets; sounds like your problem is with spark. Jet size won't affect that, though a carb clean can't hurt. My first tentative thought would be a bad CKP. If you can, get ahold of a manual for the bike (check the year first). That'll have electrical specs in it, and troubleshooting procedures.
Old 03-04-2016, 04:07 AM
xFreebirdx's Avatar
xFreebirdx
xFreebirdx is offline
spray the front intake gasket with some WD-40 while the bike is running just to rule it out..........
Old 03-04-2016, 08:08 AM
cvaria's Avatar
cvaria
cvaria is offline
teaching opportunity:
why? what will happen? are you trying to isolate a bad gasket?
Old 03-04-2016, 11:43 AM
misput
misput is offline
Senior Rider
Sounds like it is definitely in the firing, start with the least expensive item and work your way through the system.
Old 03-04-2016, 02:36 PM
xFreebirdx's Avatar
xFreebirdx
The gaskets on the intake are rubber and sort of triangle shape. The heads can get about 400 so they can tend to dry rot and crack. He should REV the bike to about 4000rpm's and spray water or WD-40 (etc.) where the intake meets the head. And if cylinder starts to misfire while spraying, more than likely it's sucking air and needs new gaskets. A free and easy test.....
cvaria (03-04-2016)
Clsd350
Dyna Parts
10-21-2016 06:49 PM
CrazyAfroCuban
Welcome Area Only
21
09-21-2016 11:24 AM
Pgh-mike
Evo Classic Models
15
06-05-2016 07:42 AM
Pdxglide
Exhaust System Topics
05-01-2016 01:33 AM
Jaime013
Welcome Area Only
18
03-13-2016 10:55 AM
Quick Reply: 2005 Harley sport xl1200Runing on back cylinder front kicks in while riding on high rpm
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
