Oil Leak, Iron 883
Oil Leak, Iron 883
Need some help figuring this out. I was riding the other day and once I parked, I noticed oil splattered all over my oil tank cover (pictured, but wiped off). I couldn't see where it was coming from, and the oil level is fine, not overfilled, about halfway up the stick. I noticed some leaking from the engine, and wondered if that was where it was coming from. I did some research and found that there are tons of cases of leaking from the rocker box gasket. But I'm not sure that's the problem because the leaks on the engine look like they're not where the gasket is. I'm not an expert by any means, just a rider. Any help would be awesome!! P.S. I don't know why the pictures are upside down. I posted them and previewed them and they were correct. Sorry.
Received 2,189 Likes
dragon92580 (03-25-2016)
John
The following 2 users liked this post by John Harper:
grbrown (05-11-2020),
Rob Roy's Revenge (07-05-2023)
Does your Mummy know you have switched the computer on ?
No dipshit
- you sound like a communist ****** if you don’t like motorcycles then don’t post a comment you ***** and go **** your self you pathetic piece of ****
Archilochus
03-11-2016 08:38 PM
