Mid controls for 2016 48.
I know there are threads on this but they're at least 2 years old.
I would like to put some mid controls on the 48. I'm seeing the Roland Sands kits but the cheaper ones say they're only for up to year 2013? Does anyone have a good place to get them currently? |
How long have you been riding the 48? The controls on the 48 are not that forward. When I bought mid controls even before I bought the bike but then I realized they are not that forward and sold the mids.
The rear master cylinder changed in 14'. RSD is coming out with one for later years. You can get mids off an 883 Iron 14' and up. I did and loved the change.
Originally Posted by OddJack
(Post 15364835)
You can use mids from 2003-2013 but u have to buy the mid control rear brake pushrod. #50600091 cause it slides into rear bar instead of the earlier ones that bolt on both ends. The link below is for a 2014 883 with mid controls and all the part numbers.
http://partstream.arinet.com/Mobile/...ZvU4lfoo1.html |
Im sorry to ask on an oldthread, but i can't find the answer anywhere. On the mid control mount, the bolt holes are covered. How do you remove them?
Newbie question,i know |
I'm not 100% but from what I know their are plastic plugs that just pop out
Newb
Originally Posted by Jman245
(Post 17073885)
installed mid controls from ebay on my friends 2017 48. everything fit properly except the rear brake pedal seems to be too low. tried to install the rear brake pedal from the forward controls and it doesnt it. any suggestions? any other brake pedal recommendations? thanks!
Originally Posted by Mikecutz
(Post 19101059)
Not sure why Harley didn't spend the extra $.25 to make the brake adjustable. You could also cut and thread your existing rod to make it adjustable if you have the tools. |
© 2024 MH Sub I, LLC dba Internet Brands
