2016 Roadster 1000 mile service questions
Received 2,189 Likes
your service manual is 99484-16A:
it's $48 at http://www.surdyke.com/
however, here is what you'll need to do for your 1000 mi service in the meantime , this is from a 2014 service manual and nothing has changed other than you forks and shocks.... most of it is covered in your owners manual available free here: https://serviceinfo.harley-davidson....cle/lookupForm
steering head: call a dealer service department to verify yours since your front end is closer to a 48.
- 99484 is the sportster/xl constant
- 16 is the year
- A for the 1/2 year revision ...
The reason so many of us keep harping on about buying the FSM is because all that stuff and so much more is contained within. You can also check on the H-D website, on the Owners tab IIRC. There is a spreadsheet-like table of the things to check and adjust at each service interval. They are also probably in your owners manual. If you don't have one of those you can download a copy from the H-D website, via the Owners tab.
