Exhaust pressure
Exhaust pressure
This morning I was looking my bike over while it was running and I happened to put my hand near the exhaust. I noticed that the exhaust pressure coming from the rear cylinder is noticeably less than that of the front cylinder. Is this normal? I would think they would have the same pressure unless something is wrong. My current exhaust set up is stock headers with aftermarket mufflers. The front cylinder's header was extended so that both mufflers would be aligned, which makes me wonder if this added length is causing the increase in pressure.
DanTheBetterMan (08-25-2016)
Thanks for the advise! I've never tested compression on a motorcycle engine, is the same as on a car? Unplug spark plugs, remove one spark plug, replace spark plug with compression tester, and crank?
It is a Nightster! I'm not sure what you're talking about when you say balance tube though. I've seem some sportsters that have a horizontal tube connecting both headers, is that it? If it is, then no, I don't have that anymore. I always thought that was just to hold them in place, does it do something else?
Remove both spark plugs and open throttle wide open while testing each cylinder. Check with an expert but I think this is right. Does both cylinders sound the same?
Thanks for all the advise guys! Once I got home I took a closer look at the exhaust when I realized that there was a hole in the side of pipe! No wonder I thought I had heard an exhaust leak. The guy that sold me the motorcycle used rigid mounts without rubber (what a knuckle head!) to hold the pipes to the engine and the vibration finally got the best of them.
