noise from primary area
Hope someone can help before I tear it down. I have a loud "whiring" noise coming from my primary side. It is more noticeable when slowing. Does not matter whether I am in gear or neutral. Still makes the noise if clutch is pulled in or out. Engine off and coasting in neutral noise is still there. Seems to be a rotational noise and keeps pace with the bike speed. Sitting still with engine running no noise. Pulling the clutch in will change the noise but it remains as long as the bike is moving. Any ideas? I am thinking that it may be the thro out bearing or inner clutch bearing.
Coasting with the engine off and tranny in neutral should mean there is no movement in the primary chain and clutch basket. It might be in the output shaft bearing, or it might even be in the wheels. Sounds can be strange that way.
But like cHarley said, more bike info would be helpful.
Sorry about the lack of information. The bike is a 1999 Sportster 1200. To update everyone in case they run into similar problem. I removed the right drive sprocket cover to check the bearing/belt/sprocket for any damage. What I found was the drive sprocket was loose, after taking the sprocket nut lock off I could actually remove the nut with my hand. After applying locktite to the nut and re-torqueing the noise was gone. So just a heads up to those that may be hunting a drive noise on their sporty.
The following 2 users liked this post by diverherb:
Max2015RGlide (10-27-2016),
TStephen (10-25-2016)
Glad to hear it was a "simple" fix. It's a pretty high torque value on that pulley nut, I think in the 200ft.lb. range. Are you certain you got it cranked on there good?
Actually I think the book called for a torque value of 50 ftlbs+30deg. which I thought pretty wimpy, but the nut is fine thread and thin so anything much over that would probably strip the threads. So far so good. I actually over tightened the nut and the bolts holding the locknut I used red Loctite on everything. Hopefully it will be okay.
TStephen (10-27-2016)
RPDLV
11
05-30-2019 10:23 PM
Road King Kid
05-03-2007 11:00 PM
