SBS Project - Sportster Chop w/ Lots of Photo's
#322
Received 3,939 Likes
Yeah, with a bit of old creaky bones comfort slipped in there...I'm chomping at the bit to get it done...but it's gonna be a while yet with all the other stuff going on.
#324
In a previous post I showed where we were test fitting some Chrome floorboards on this bike.
We worked on several different designs of mounts...kludging some ideas together with scrap metal, welding, drilling, tapping and grinding.
I wanted the boards to be as tucked in as possible, and to mount off the factory clevis.
We got some machined up and then sent them off to powder. Got them back last week.
While working on them for this bike, I got to thinking, I bet they would be comfortable on my other Sporty.
So I mounted up a set of Black Floorboards on the DK Sporty. Been riding with them the last few days.
WOW!!! I just started out with this idea because I thought it would be good for this SBS Chop with the Suicide Clutch.
It is amazingly more comfortable And stable feeling at speed. Plus I have More lean angle!
The black ones are staying on this Sporty and the Chrome ones are going on the SBS Chop.
Kevin
Kevin
#326
No serious vibes. It is the same, or a little less than with pegs. BUT, it does feel different with the whole foot being supported instead of just a portion.
Different Sportys vibrate differently...mine does not vibrate much going thru the RPM''s, but definitely has a bit more in the 75-85 mph range in 5th gear. (883 gearing)
Prior to these boards I was comfortable cruising up to 75 mph...I would pop up to 90 mph passing, but never comfortable cruising there. I've been to 95 mph more than a few times and 100 mph once. I definitely did not feel comfortable sustaining that speed.
With the floorboards I was cruising between 85 and 95 mph the other day and it was rock solid, totally comfortable. Still have not figured out quite why. Theories are that the wind is no longer hitting my boot bottoms, fighting to push them off the pegs. Also, I seem to be sitting on the seat differently.
Kevin
The following 4 users liked this post by DK Custom:
dirtdreamer50 (06-30-2017),
rowan (12-31-2017),
Søren Rix Petersen (06-29-2017),
splattttttt (06-30-2017)
#327
Received 4,916 Likes
A- rigid frames are perfectly acceptable for the long haul as long as you have a seat with a suspension. The MoCo knew what it was doing back in the day with the pogo seats. Very comfortable and only the worst of bumps get it to bottom out and then send the shock to your lower back. If my '70 FLH was not a two up bike I would go with a factory pogo and have the best of both worlds, shocks and suspension seat. Then it would really be the King of the Highway.
B- Floor boards definitely work better then pegs for a bunch of reasons including the ability to move your foot around and still be supported. Do they look as good as pegs, depends on the bike. I agree with the wind on your boot as part of the increased comfort, or lack of wind. I think it also allows your foot to be in it's natural position and not locked into a perfectly straight location as dictated by the pegs.
Keep going, the bike is looking good.
#328
Yes, the pads are solidly mounted to the boards...no cushioning in between them. They are rubber, so they have a bit of intrinsic isolation.
Kevin
Kevin
I also found that my foot could move to many other positions while riding aiding comfort
And if you ever think of making those board mounts and selling them
they seem to bring the boards in nice and tight
#329
Kevin
#330
Yes, I am getting soft in my old age. My other Sporty has a spring seat, reworked front suspension, and 13" rear shocks.
Softail has reworked front suspension and with the factory rear suspension it just floats over the bumps.
TG has reworked front suspension, and highly refined rear suspension, it not only handles extremely well, but eats up the bumps almost as good as the Softail.
I'm hoping between reworking the front suspension and having a good seat and seat suspension, that this SBS Sporty is a comfy ride for my old bones. lol
I couldn't believe how much vibration was dispersed across the boards.
Working on it...should not be long.
Kevin
