Battery dead. Only have tender. Can i use my car?
Went for the last ride of the season to put it in storage, just to find out that it wont start, battery is mostly dead. Havent started it in a month, and temperature between 25 and 40.
Now can i jump start it with my car? Or should i remove the battery and use a tender? I dont have a battery charger...
I just want to make a five minutes ride to the storage place.
12 volts is 12 volts, the only reason the system would draw more amperage than needed is if there were a short in the system or a defective electronic component, and even in that case the 30 amp main fuse would blow.
But there is no reason to have the car engine running to jump start a motorcycle engine...
OP: Buy a battery charger.
The following 2 users liked this post by Dan89FLSTC:
aecs (12-12-2016),
SIDECAR BOB (12-11-2016)
The stock motorcycle battery can supply well over 100 amps...
Connect the positive cable (red)(+) to the positive post (+) of the dead battery. Connect the other end of the positive cable to the good battery. Connect the negative cable (black)(-) to the negative post of the good battery. Connect the negative cable to a metal part of the dead vehicles engine.
I did this several times in the cold weather with my 48 but the 4 wheeled vehicle was running every time and never had any issues. I guess I just got lucky. Now i just keep the tender connected when the bike sits for extended periods of time due to the posts I've read about the possible damage that may be caused.
If anyone selects to go with the C Tek tender, they have a pigtail with 3 different colored LEDs to tell you how your battery is doing before you try to start your bike. Unfortunately it is a different plug from the Harley tenders and they cost around $10, if mine is flashing red the bike wont start.
Ratwerke (12-15-2016)
