Can I run dual fire cool with single fire ignition?
Old 03-20-2017, 02:35 PM
rouskie's Avatar
rouskie
rouskie is offline
6th Gear
Default Can I run dual fire cool with single fire ignition?
I'm restoring a 1982 xlh 1000 that didn't have the ignition module so I decided to order the compufire single fire ignition. I still have the stock ignition coil on the bike, are they compatible? Should I cancel my order and get the dual fire instead? Any info helps!
Old 03-20-2017, 02:59 PM
j_bee's Avatar
j_bee
j_bee is offline
As far as I'm aware you can't run the dual fire coil with the single fire ignition.
A single fire coil is likely to have a 12 volt supply wire and a trigger wire for both the front and rear cylinder, so esentially three imputs.
Where as the dual fire will have only 2 imputs. A 12 volt supply and a trigger wire supply from the ignition unit.
Depending on the level of restoration you are doing I think keeping things as standard as possible is best.
Old 03-20-2017, 05:45 PM
Scuba10jdl's Avatar
Scuba10jdl
Scuba10jdl is offline
No. You need to match the coil to the ignition type.
Seanrlynchh
04-13-2013 06:15 PM
tymatt67
09-23-2012 08:54 AM
hdbeggs
02-14-2011 02:22 PM
waynemags
EVO
05-28-2009 02:41 PM
hddee
Shovelhead
04-23-2008 09:09 PM
Quick Reply: Can I run dual fire cool with single fire ignition?
