noise coming from primary drive
04-05-2017, 03:02 PM
I have a 1989 sportster 883 that has just started making a rattling sound when under a load. The noise is not there while the bike is in neutral and it seems to go away at higher rpms. It only happens when the engine is hot.
Any ideas ?
04-05-2017, 03:42 PM
Quote:
Originally Posted by
bigdan63
Any ideas ?
check chain tension before digging deeper.
04-05-2017, 04:33 PM
Thanks for the suggestion , but that was the first thing i checked and it is within spec.
04-05-2017, 05:42 PM
Ping or knock maybe?
Have you changed anything latley?
04-05-2017, 06:18 PM
HOTLAP
Ping or knock maybe ?
+1 The described symptoms sound like ping.
Fill up with premium octane gas and see if that changes things. Drain the existing fuel is necessary.
04-05-2017, 06:50 PM
Thanks for the suggestion but it's not a ping. it is knock at low rpms and only when the engine is hot. Maybe i should let it cool off more often ?
i only run premium.
04-05-2017, 06:53 PM
No i haven't changed a thing. It only occurs when the engine is hot , and i run premium gas always.
It was really noticeable this past weekend while riding in the mountains , especially going uphill.
04-05-2017, 07:21 PM
I'd check the primary chain again. Check it in multiple spots. Not just one.
04-10-2017, 05:02 PM
Thanks , i took your advise and adjusted the primary chain. Turned the adjustment screw about 1/4 turn. Noise went away !
Thanks Again
04-10-2017, 09:07 PM
Honda45
06-29-2015 05:09 PM
Abandoned
08-18-2013 02:57 PM
Falcon195
08-02-2013 04:11 PM
nealhix
08-19-2012 10:25 PM
Rockhanger
10-12-2011 01:42 PM
