Help, Stripped Screw in Handle Bar Control!
You should be able to drill that and then remove the shaft with a pair of vice grips.
Be careful drilling it so that you don't over drill and get into the shaft of the screw.
Go gently with a drill bit that's the size of the bolt shaft (3/16"??) and take it slow. As soon as the head comes loose on the drill bit and starts to spin, stop drilling.
In the pic the OP posted, that screw looks like a typical aluminum screw. Another thing I've done in the past is used a small file and filed a slot into the screw head and then used a straight screwdriver to back it out.
Huh, must just be your luck. I've always had the easy outs work on aluminum screws. Now, hardened bolts and such... I've had no luck with them either.
You can also sometimes get a torx bit that is a tight fit, tap it in with a hammer and use it like an extractor as well.
Lot's of options.......all of them suck compared to a non-stripped bolt.
