2007 Harley Davidson sportster 1200 xl custom
See the diagram below for your year and model. If you're looking for item 14 then it's the Oil Drain Line Sleeve, p/n 33138-06. If you're looking for item 21, then it's the Oil Drain Hose, p/n 63596-06.
HTH.
HTH.
# 21 from the parts drawing above is what usually fails, breaks / cracks at the tight bend in the middle. I replaced mine some time ago, not difficult just need patients.
Most likely the MEC did not tighten the #4 item (hose clamp) tight enough, 9000K is not enough time to fatigue the rubber that much, but, if it is buy 2 as you will need it soon. Each bike has her qwirks (like wom. . . ) !
Enjoy the repair, and get use to it.
JOE DANIEL (02-03-2024)
Godfather86
02-12-2007 10:06 PM
