Prime the Oil Pump?? 1993 XLH1200
I've got everything ready to go (almost) to fire up the old girl after a long time on the jack. I did top end work, removed and inspected tranny, oil pump, put a new clutch in, etc...
I want to be sure I haven't overlooked anything before putting fire in the cylinders. I figured I'd tap the enormous wealth of knowledge on this great forum.
Somewhere I read (on a forum) about a guy with a '91 trying to "prime" his oil pump.
I didn't think that was even a thing, but thought I'd be safe and look through my FSM. Nowhere do I see any procedure for "priming" the oil pump.
Is this a legit procedure? If so, where do I find information about it?
Is it something that older (pre-1993) Sportsters needed?
Do I need to worry about priming my oil pump?
I guess everyone was out having fun, this forum is not exactly a barn burner you know There are probably ways to prime the pump and even the whole system but all I know about is to fill the oil filter before you install it and when you fill the oil tank I think some oil will go to the lower part of the engine. If the pump does not pick up oil almost immediately I would think it was a sign of worn out pump.
TStephen (04-24-2017)
