Black Betty: 2007 XL1200C Build/Mod Thread
Old 04-24-2017, 04:11 PM
BlackBettyXLC's Avatar
BlackBettyXLC
BlackBettyXLC is offline
Originally Posted by deadrubberboy
Thanks! Undecided on bars. I like them now, but that may change depending on rise/pull back of new riser etc.
Is 68513-95a the new "idiot lights" to fit the non-C housing?
Part # 68813-07 is the actual harness that includes the new dummy lights and speedo connector, while 68513-95A is the jewel lens that goes over the dummy lights in the speedo housing (listed below). Yeah, 17 freakin smackers for that little piece of ish!
Old 04-24-2017, 09:51 PM
BlackBettyXLC
Default Removed tank trim, new gas cap
When I bought the bike, it had the optional Custom model tank trim attached to it. I decided to remove since I liked the look of a clean tank without anything splitting it up better than it was with it on.
I used some WD-40 to loosen up the adhesive for a bit then used a hair dryer to heat up the adhesive to ease removal by shimmy-ing some fishing line between the loose adhesive and the tank. It came loose, but if I had to do it over again, I would NOT use this method. I bought some 3M adhesive remover to clean up the remainig adhesive and it is leaps and bounds better than WD-40. It practically eats the adhesive after sitting a few minutes and really makes things easy. If you're thinking of doing this, go so slowly that it almost hurts. I thought I was going slow and a good bit of adhesive was left over and I had lots of fine scratches all over my paint from the fishing line. I was unhappy to say the least. I would probably use floss and the 3M adhesive remover with hair dryer/heat gun if I had a second cracking at it.
Before:
Tank trim w/ Willie G medallion on stock cap. Bye bye...
Here is the tank after a healthy clean-compound-polish-wax process and my new smaller black gas cap fitted with the Dark Customs medallion. I decided to do black on black with the Dark Customs trim to go with the Dark Customs derby cover, tranny cover, and eventually my air cleaner trim I'll be doing soon. I've always liked the Dark Customs logo and I'll be sticking with it.
Nice and clean (excuse the dust)
Old 05-12-2017, 09:16 AM
BlackBettyXLC
Default SG Air Shocks
After riding on the stock shocks for about 6k miles and bottoming out multiple times while riding 2-up or when I hit potholes, I decided it was time to do somethin different with the suspension. I looked at quite a few options: Progressive, Ohlins, Burly, etc. Then I happened on a few articles about air shocks from touring models. After a bit of readin and discovery about the affordability, adjustability, and substantial ride improvements they can bring, I decided to go for it. I searched for a while and picked up a set of used 2015 Street Glide air shocks and fittings with only ~1k miles on them from a forum member.
Install was fairly simple once I found the proper way to jack up the frame so that the lower shock mount properly aligned with the eye on the swing arm. Some say to do one shock at a time so you don't have to use a jack, but this did not work for me. Even when doing one shock at a time AND using a jack to lift the bike so the swing arm was in a relaxed position, the shock eyelets would not line up with holes on the bike. So instead, I jacked the bike up so the rear wheel was barely lifted, then took both shocks off while it was supported and put the new shocks on while raising/lowering the bike as needed to line up the holes.
Everything taped off to avoid trashin the pain during install.
Two thick washers in between each shock to frame mounting point, top and bottom. This provides clearance between the belt guard and the thicker air shocks. I reused all the stock bolts which were long enough to accommodate the extra washers​​​​​​.
I routed the tubing from the shocks behind the oil tank and behind the battery cover and undwr yye seat on the other side for a nice clean install with minimal tubing showing.
This is where the Schrader valve will go for now. Hidden right under the seat near the tank on the right side.
A shot of the finished product. No noticeable difference in ride height, but a huge difference in handling for the better.
cvaria (06-20-2017)
Old 05-12-2017, 11:44 AM
deadrubberboy's Avatar
deadrubberboy
deadrubberboy is offline
Nicely done!
Old 05-12-2017, 04:12 PM
BlackBettyXLC
Nicely done!
Thanks, man. It's comin along. Should have new rubber on sometime this weekend!
Side note: you got your sissy bar from that guy on Etsy, right? I was lookin at his work and it looks solid. And a lot more affordable than most other places. How's yours holdin up?
Old 05-12-2017, 05:01 PM
BlackBettyXLC
Default Smoked Out Lighting
Ever since I got the bike, I never did like the look of that big honkin eyesore of a taillight so I set out to find a low profile alternative that was also smoked out. I also wanted to do the signals as well since they stick out like a sore thumb.
After a lot of researching and refusing to pay out the butt for a taillight, I settled on the MoonsMC LED run/brake taillight. They've done some things with their taillights to set them apart from most of the other comparable Chinese knock offs on eBay and Amazon. Wiring pigtail is done well, the LED board is blacked out for a stealth look, and there's a nice little weather gasket on the back of the board to block out debris and water. It's workin great so far.
Everything turned out real slick. I love the look and the red and orange lenses are no longer sticking out and distracting from the rest of the bike.
Before:
Fit and finish of MoonsMC light
After:
cvaria (06-20-2017)
Old 05-12-2017, 06:16 PM
deadrubberboy
I did, and it's great. He actually made it with custom measurements to accommodate my seat. Highly recommended.
Old 05-12-2017, 06:29 PM
Ben Bradke's Avatar
Ben Bradke
Ben Bradke is offline
Stage I
Default 04 sporty sticky choke
Was going to go for a ride but when I went to pull the choke out to start the bike it only moved out a hair. I went for a ride last night and everything was beautiful, nothing was wrong. I tried spraying carb cleaner in the carb but that didn't help. I just bought the bike and the previous owner had it sitting in his garage for 2 years.
Old 05-13-2017, 12:21 PM
jlb2782's Avatar
jlb2782
jlb2782 is offline
Very nice bud. And you'll be happy with the sissy bar. Guy is super cool.
Old 05-14-2017, 12:53 PM
BlackBettyXLC
Sweet. Yeah, I like that he does custom measurements and can add/delete components per request. Lookin forward to gettin a black bar to complement the theme.
Uhhh, I think you're in the wrong thread, bud.
Yezzir. Can't wait to get rid of the chrome sissy bar. It's served it's purpose in supporting the lady friend, but having a blacked out bar that looks good AND serves a purpose will be better.
Quick Reply: Black Betty: 2007 XL1200C Build/Mod Thread
