front end shimmy
ok, bit of an update here
Front and rear tire pressures set at 40psi (max front is 41psi as per sidewall)
No change
Adjusted front stem bearings, they seemed a bit loose, but were still in spec....
Jury is still out. need to take it up on the slab to see what happens, problem is, we have about 25mph winds today, and dont want that skewing the check. will take it out in the early AM to see what happens when its calm out.
rear bearings checked out good, both wheel and swingarm. Tire balances are good.
No change
