Engine/Transmission case weight?
Hello all,
I am looking to ship a used 2008 sportster 1200 engine/transmission case from the USA to Israel so I need a good guess as to weight of the aluminum case & bearings (without the main crank or gears). It is simply too expensive to attempt a rebuild, all the parts alone are over 2K so the next best is a used case that has everything in good running order.
If anyone is in the middle of a rebuild I would really appreciate a scale reading.
Cheers,
Cheers,
Lucas Lynch
Engine Mechanical Topics
06-11-2017 09:30 PM
