Running lean after hammer 1250 basic conversion
Hey guys, a quick run down of what my issue is. I have an 01 883 that I just did the hammer 1250 basic conversion on. I kept stock heads and stock ignition (just retarded it a little). I put in a 45 pilot and 185 main, the bike HATED the 45, wouldn't stay running unless I was at 1/4 throttle and it was puking black smoke, even with the mixture screw at 2 turns out. I put the 42 pilot back in and it ran much better, except it's running lean (plugs are white) and it's popping and back firing on deceleration, even with the mixture screw about 5 turns out. I asked hammer and they had no idea what could be the issue, said they've never seen a bike not like the 45 pilot like mine did. Any one here have some advice of what may be going on? Thanks in advance
You should have no problem with a 45 unless you have other issues.
Have you cleaned out your carb passages?? Take out mix screw, pilot jet and blast it out with carb cleaner from the air bleed at the mouth. Check to make sure the "o" ring on the mix screw is not damaged, or one is not still down in the hole. Sounds like an idle circuit issue. Double check your intake seals if this is a new installation.
John
John
Just went and picked up a 45 from my local Harley dealership. I compared the 45 I got from hammer and the one I just got. The hole on the jet from hammer is about three times the size as the one I just got. Anyone ever had this issue? Possibly just a faulty jet, or do hammer jets run that much bigger?
