Sportster squealing noise
I have a 2002 Sportster 1200 with just under 5000 miles on it. I have had a squealing noise while I ride. It doesn't squeal in neutral while rolling or when the clutch is pulled in. The squeal is noisiest in 3rd and 4th gear while accelerating. When I let off the throttle, no squeal. Oil and gear oil has been changed. The squeal seems to be coming from the front left area. Any thoughts on what this might be and how to get rid of it?
I'm not sure on this one but maybe check the primary chain tension?
Curious what others have to say. |
+1 check the primary chain tension first
Tough to say without hearing it. Maybe clutches? Just a thought
Originally Posted by maverick31210
(Post 16562901)
Originally Posted by T_Hank63
(Post 16563031)
I tightened the primary chain a few weeks ago. Just checked it and it seems to be loose again. I'll tighten it up and see if there is a difference in the noise
(Post 16563036)
Report back on how it goes man, curious about it.
(Post 16563416)
Took it out for about a 15 minute ride. Squealed the entire time. 3rd and 4th gear is still the worst with the noise
(Post 16563451)
Depending on how alarmed/annoyed you are at this, you can pull the trans out and check the gears. See if you notice any unusual wear. Once you get the primary out of the way, the trans is held in by 5 bolts and comes out as an assembly.
(Post 16563514)
Are there any other possibilities before having to open that up? With under 5000 miles I would really hope something wouldn't be wrong within the transmission
I wouldn't expect trans issues that early either, mine shit around the 40K mark. |
© 2024 MH Sub I, LLC dba Internet Brands
