Suspension upgrade advice
Before anyone asks, yes, I did read the entire suspension sticky on the XL Forum and it has a ton of great information, but could still use some advice. I am currently running 12.5" progressive 412's on the back and progressive springs up front with rider sag set to 25% of travel. I'm starting my next set of upgrades that include better shocks, Bassini road rage exhaust, and a Hammer 1275 kit, the latter 2 I'm already set on.
I weigh 205 in gear and ride 2 up approximately 15% of the time. Passenger is either my 75 lb daughter or my 160 lb wife. I'm moving to 13" shocks and have a $750 budget for the shock upgrade. I'm looking for something that gives a comfortable ride for a long day in the saddle while still being able to handle the twisties with relative ease. Current contenders are Ricor, Race Tech, and Legend.
Thanks in advance.
Thanks in advance.
Just another option to think about....
I run these Bitubos and I am very pleased with the comfort @ below your budget.
http://www.dkcustomproducts.com/twin...dk-bt-shks.htm
But it did say this....* These shocks are made in Italy. If you are running over the Gross rider/passenger/luggage combined weight, they will not perform as well as the Pro-Action Shocks. Pro-Action Shocks are Made in The USA.
Although only slightly over your budget, probably well worth the few extra bucks.
https://www.dkcustomproducts.com/pro...dk-pas-shk.htm
DK Custom (09-24-2017)
Received 3,931 Likes
Thanks in advance.
Thanks in advance.
Here are a couple of Reports with Comparison Charts from extensive testing.
Front Suspension Testing Report
Rear Shocks Testing Report
I did the progressive monotube cartridges in the front end, and 12" progressive 490s in the rear.
I ride solo but have ridden two up and not had an issue with the rears. I weigh 175 and my passenger weighs 160.
Hope that helps. If you have any questions about the setup and I can try to answer them to the best of my ability.
